Ga door naar hoofdinhoud
Nintendo DS Lite Shoulder Buttons Replacement
Wat je nodig hebt
  1. Nintendo DS Lite Shoulder Buttons Replacement, Remove the battery cover: stap 1, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the screw securing the battery cover.
  2. Nintendo DS Lite Shoulder Buttons Replacement, Remove the lower case: stap 2, afbeelding 1 van 1
    • Use a spudger to pry out the battery.
    • Pry off the rubber feet.
    • Remove the seven screws securing the lower case:
    • Three tri-wing screws
    • One Phillips screw
    • Two gold Phillips screws
    • One black tri-wing screw
  3. Nintendo DS Lite Shoulder Buttons Replacement: stap 3, afbeelding 1 van 1
    • Carefully pry the bottom cover off.
    • Remove the shoulder buttons by pulling out the metal pegs that secure them to DS.
    • The triggers are held in by tiny metal pegs and springs. Keep track of each piece.
  4. Nintendo DS Lite Shoulder Buttons Replacement: stap 4, afbeelding 1 van 3 Nintendo DS Lite Shoulder Buttons Replacement: stap 4, afbeelding 2 van 3 Nintendo DS Lite Shoulder Buttons Replacement: stap 4, afbeelding 3 van 3
    • You can now access the micro-button component and replace or repair anything as needed.
Conclusie
To reassemble your device, follow the steps in reverse order after making your repair.
5 andere personen hebben deze handleiding voltooid.
3 opmerkingen
For anyone dealing with unresponsive shoulder buttons, I highly recommend watching this video guide;
https://www.youtube.com/watch?v=VnWdawXC...
Gabriel Branyiczky - Antwoord
たしかにそうですね!!!
kawagoe -
とても、わかりやすくて、しっかり修理できました!
kawagoe - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 54
Afgelopen 30 dagen: 243
Altijd: 6,448
