Ga door naar hoofdinhoud
Nintendo DS Lite Battery Replacement
Wat je nodig hebt
  1. Nintendo DS Lite Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Nintendo DS Lite Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Unscrew the Phillips screw securing the battery cover to the lower case.
    • The screw remains captive to the battery cover.
    • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
  2. Nintendo DS Lite Battery Replacement: stap 2, afbeelding 1 van 1
    • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
    • Remove the battery from the DS Lite.
Conclusie
46 andere personen hebben deze handleiding voltooid.
Matthew Newsom
39.527 Reputatie
67 handleidingen geschreven
5 opmerkingen
Can you describe the type of screw and captive washer ?
Cornel Paraschiv - Antwoord
Thank you.
i just ordered a new battery as I already got a new power cord & it won’t charge at all.
Hoping new battery does the trick.
Thanks again.
T. Kellogg
Tamela Kellogg - Antwoord
Thanks but will a dsi battery work
Zach - Antwoord
My battery cover won’t come off.
Jake - Antwoord
Flip the console upside down and it will but don’t pull it will break hold it close to the console then slide it back
dead -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 16
Afgelopen 7 dagen: 202
Afgelopen 30 dagen: 891
Altijd: 53,769
