Inleiding
After removing the circuit board, the bottom LCD screen can easily be removed from the Nintendo DS.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Remove the cartridge from the console.
Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
Remove the battery door.
Using a Phillips #00 screwdriver, remove the four screws on the circuit board.
Peel off the back foam on the bottom touch screen to expose the ribbon cable.
Gently lift the screen out of the base.
15 andere personen hebben deze handleiding voltooid.
Één commentaar
I like it but add a step 12 maybe, to see how to put in a new screen.
