Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the cartridge from the console.
Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
Remove the battery door.
Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic opening tool or spudger isn't available, your fingernails may work.
Remove the seven 6.4mm Y00 screws located on the back.
With your hands, pry the back panel off the main case.
Separate the back from the front, and set it aside.
17 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Where do I get a nintendo DS gamepak?
