Ga door naar hoofdinhoud
Nintendo 64 Motherboard Replacement
Wat je nodig hebt
  1. Nintendo 64 Motherboard Replacement, Top Cover: stap 1, afbeelding 1 van 1
    • Remove the expansion pack cover by pushing in the tab and pulling out.
  2. Nintendo 64 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • If your system uses a jumper pack, the same procedure applies to remove it.
    • A small spoon can be used in place of a spudger.
    • Lever the expansion pack out using a metal spudger.
  3. Nintendo 64 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
  4. Nintendo 64 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Remove the two front feet of the N64.
  5. Nintendo 64 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Rotate to top side up and lift off top cover.
  6. Nintendo 64 Motherboard Replacement, Metal Plate: stap 6, afbeelding 1 van 2 Nintendo 64 Motherboard Replacement, Metal Plate: stap 6, afbeelding 2 van 2
    • Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
    I’m not entirely certain if it's a common difference, but my nintendo 64 doesn’t have fourteen screws, but rather, 8 screws, and instead of 3 heat sinks, it only has the one separate heat sink on the chip close to the memory expansion pack. additionally, aside from the 6 screws closest to the expansion pack, the two other screws are held on by nuts under the metal piece.
    Avery Duncan - Antwoord
  7. Nintendo 64 Motherboard Replacement: stap 7, afbeelding 1 van 2 Nintendo 64 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Remove the metal plate indicated in the example by sliding it back and then lifting it up.
  8. Nintendo 64 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Remove the two screws indicated in the example using the smaller Phillips screwdriver.
  9. Nintendo 64 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the screw to the right of the LED light using the larger Phillips screwdriver.
  10. Nintendo 64 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Remove the small metal bracket from the back of the expansion pack slot.
  11. Nintendo 64 Motherboard Replacement: stap 11, afbeelding 1 van 2 Nintendo 64 Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
    I have noticed this is not in Australian Pal versions of the N64.
    at First i thought i was missing a bit on my N64 and now have looked a second one and its also not there.
    Darren Welch - Antwoord
  12. Nintendo 64 Motherboard Replacement: stap 12, afbeelding 1 van 2 Nintendo 64 Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Remove the small metal bracket behind the expansion slot using the spudger.
  13. Nintendo 64 Motherboard Replacement: stap 13, afbeelding 1 van 2 Nintendo 64 Motherboard Replacement: stap 13, afbeelding 2 van 2
    • Remove the seven screws indicated in the example using the larger Phillips screwdriver.
    The two screws next to the cartridge slot are longer
    Michael - Antwoord
  14. Nintendo 64 Motherboard Replacement: stap 14, afbeelding 1 van 1
    • Lift off and remove the metal plate as indicated in the example.
  15. Nintendo 64 Motherboard Replacement, Motherboard: stap 15, afbeelding 1 van 1
    • Remove the four screws indicated using the #1 Phillips screwdriver.
    I found the #2PH to work a bit better here
    Rand Avary - Antwoord
  16. Nintendo 64 Motherboard Replacement, Motherboard removal: stap 16, afbeelding 1 van 1
    • Lift up and remove the motherboard.
Conclusie
36 andere personen hebben deze handleiding voltooid.
tonymag28
2.159 Reputatie
3 handleidingen geschreven
Cal Poly, Team 5-4, Regan Fall 2009 Lid van Cal Poly, Team 5-4, Regan Fall 2009
CPSU-REGAN-F09S5G4
7 Leden
15 handleidingen geschreven
3 opmerkingen
4.2mm doesn't seem right. When I looked to purchase all I saw was 4.5mm and now that I have one in my hand it seems to fit very precisely on the screws on my N64.
negroslim - Antwoord
i got the second comment :whyy:
Sqwerks - Antwoord
What are the symptoms of a bad motherboard?
Jon - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 56
Afgelopen 30 dagen: 482
Altijd: 63,802
