Inleiding
If the red LED light on the front of the console does not light up when the power is on (and you care about the cosmetics of your system), this guide will allow you to replace the bulb
Wat je nodig hebt
After the top cover of the console has been removed, focus attention on the front of the motherboard. You will see the red LED bulb.
Once the pins are through, and you have positioned the new bulb as the old one was positioned, heat up the area surround the holes and the pins with the soldering iron. Then touch some soldering metal to this hot area. It will form a bond between the pin and the motherboard and allow for electricity to flow and power the bulb.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Hey just a quick question, I did this but now the led turns on for a few seconds and then starts blinking and eventually turns off i tried a couple different led bulbs but still have the same issue. if there is a fuse or something that goes bad or something like that do you happen to know anything about that?
