Inleiding
If your N64 controller (model NUS-005) buttons feel less responsive, this guide will show you how to replace the N64 action buttons (A, B, and the arrows). The N64 buttons are used to interact with the game and are needed to perform actions. Over a long period of usage time, the N64 controller will become less responsive. This is due to the rubber contact membrane (the rubber layer that's on the buttons) wearing off and needing to be replaced. Replacing your buttons and rubber content membrane will fix the unresponsive issue and make it feel like a brand new controller.
Wat je nodig hebt
Use a Phillips #00 screwdriver to remove the screws from the backside of the controller.
Pull the back shell away from the rest of the controller.
To reassemble your device, follow these instructions in order
Één andere persoon heeft deze handleiding voltooid.
