Ga door naar hoofdinhoud
Nintendo 64 Bottom Cover Disassembly
Wat je nodig hebt
  1. Nintendo 64 Bottom Cover Disassembly, Top Cover: stap 1, afbeelding 1 van 1
    • Remove the expansion pack cover by pushing in the tab and pulling out.
  2. Nintendo 64 Bottom Cover Disassembly: stap 2, afbeelding 1 van 1
    • If your system uses a jumper pack, the same procedure applies to remove it.
    • A small spoon can be used in place of a spudger.
    • Lever the expansion pack out using a metal spudger.
  3. Nintendo 64 Bottom Cover Disassembly: stap 3, afbeelding 1 van 1
    • Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
  4. Nintendo 64 Bottom Cover Disassembly: stap 4, afbeelding 1 van 1
    • Remove the two front feet of the N64.
  5. Nintendo 64 Bottom Cover Disassembly: stap 5, afbeelding 1 van 1
    • Rotate to top side up and lift off top cover.
  6. Nintendo 64 Bottom Cover Disassembly, Metal Plate: stap 6, afbeelding 1 van 2 Nintendo 64 Bottom Cover Disassembly, Metal Plate: stap 6, afbeelding 2 van 2
    • Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
  7. Nintendo 64 Bottom Cover Disassembly: stap 7, afbeelding 1 van 2 Nintendo 64 Bottom Cover Disassembly: stap 7, afbeelding 2 van 2
    • Remove the metal plate indicated in the example by sliding it back and then lifting it up.
  8. Nintendo 64 Bottom Cover Disassembly: stap 8, afbeelding 1 van 1
    • Remove the two screws indicated in the example using the smaller Phillips screwdriver.
  9. Nintendo 64 Bottom Cover Disassembly: stap 9, afbeelding 1 van 1
    • Remove the screw to the right of the LED light using the larger Phillips screwdriver.
  10. Nintendo 64 Bottom Cover Disassembly: stap 10, afbeelding 1 van 1
    • Remove the small metal bracket from the back of the expansion pack slot.
  11. Nintendo 64 Bottom Cover Disassembly: stap 11, afbeelding 1 van 2 Nintendo 64 Bottom Cover Disassembly: stap 11, afbeelding 2 van 2
    • Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
  12. Nintendo 64 Bottom Cover Disassembly: stap 12, afbeelding 1 van 2 Nintendo 64 Bottom Cover Disassembly: stap 12, afbeelding 2 van 2
    • Remove the small metal bracket behind the expansion slot using the spudger.
  13. Nintendo 64 Bottom Cover Disassembly: stap 13, afbeelding 1 van 2 Nintendo 64 Bottom Cover Disassembly: stap 13, afbeelding 2 van 2
    • Remove the seven screws indicated in the example using the larger Phillips screwdriver.
  14. Nintendo 64 Bottom Cover Disassembly: stap 14, afbeelding 1 van 1
    • Lift off and remove the metal plate as indicated in the example.
  15. Nintendo 64 Bottom Cover Disassembly, Motherboard: stap 15, afbeelding 1 van 1
    • Remove the four screws indicated using the #1 Phillips screwdriver.
  16. Nintendo 64 Bottom Cover Disassembly, Motherboard removal: stap 16, afbeelding 1 van 1
    • Lift up and remove the motherboard.
  17. Nintendo 64 Bottom Cover Disassembly, Nintendo 64 Bottom Cover Disassembly: stap 17, afbeelding 1 van 1
    • Remove everything from the bottom cover.
Conclusie
24 andere personen hebben deze handleiding voltooid.
tonymag28
2.279 Reputatie
3 handleidingen geschreven
Cal Poly, Team 5-4, Regan Fall 2009 Lid van Cal Poly, Team 5-4, Regan Fall 2009
CPSU-REGAN-F09S5G4
7 Leden
20 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 104
Altijd: 42,574
