Ga door naar hoofdinhoud
Nintendo 64 Rumble Pak Battery Replacement
Wat je nodig hebt
  1. Nintendo 64  Rumble Pak Battery Replacement, Rumble Pak Battery: stap 1, afbeelding 1 van 1
    • Remove the Rumble Pak from the controller by pressing the release button and pulling the Rumble Pak out.
  2. Nintendo 64  Rumble Pak Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery cover from the Rumble Pak by pressing the tab and pulling the cover up.
  3. Nintendo 64  Rumble Pak Battery Replacement: stap 3, afbeelding 1 van 1
    • Press each battery toward the spring, then pull toward you to remove the batteries from the Rumble Pak.
    • When inserting the new batteries, make sure the positive (+) end of the battery touches the flat piece, and the negative (-) end touches the spring.
  4. Nintendo 64  Rumble Pak Battery Replacement: stap 4, afbeelding 1 van 3 Nintendo 64  Rumble Pak Battery Replacement: stap 4, afbeelding 2 van 3 Nintendo 64  Rumble Pak Battery Replacement: stap 4, afbeelding 3 van 3
    • Check for corrosion around the springs and the flat plate where the batteries touch.
    • Do not touch the corrosion. It may be battery acid.
    • Use a flat head screwdriver to chisel away the corrosion, and use a Q-tip to wipe it clean.
    • Do not use water to wet the Q-tip, as water can damage the Rumble Pak.
Conclusie
Carly Bowen
305 Reputatie
1 Handleiding geschreven
Texas Tech, Team 3-6, Rauch SU 2015 Lid van Texas Tech, Team 3-6, Rauch SU 2015
TTU-RAUCH-SU15S3G6
3 Leden
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 42
Altijd: 4,121
