Inleiding
If you have noticed that the left shoulder button on your Nintendo 3DS is no longer registering your presses, it may be due to a faulty left bumper and/or ribbon cable. Over time, the left bumper assembly and ribbon cable can become worn out or damaged, causing the button to malfunction. In this guide, we will provide you with the necessary steps to replace the left bumper and left ribbon cable on your 3DS. By following these instructions, you can restore the functionality of your left shoulder button and enjoy your gaming experience once again.
Wat je nodig hebt
Locate the battery cover panel on the back of the device.
Unscrew the two screws on the battery cover panel with a Phillips #00 screwdriver.
Remove the battery and battery cover panel.
Locate the two screw covers on the bottom of the back panel, near the middle of the device.
Insert the tip of a flathead screwdriver or spudger and gently pry the cover off by applying upward pressure.
Remove the two screws located behind the screw covers using a Phillips #00 screwdriver.
3 opmerkingen
No steps on how to install the new bumper?
good but i wish there were reinstall instructions
