Inleiding
This is a guide on how to replace the hinge/midframe of the Nintendo 3DS XL. A broken hinge on the 3DS XL can lead to more damage to the midframe if left broken. This leads to the device not closing properly or feeling uncomfortable to use. Thus, it is necessary to replace the midframe when it becomes too damaged. The process of replacing this part is a bit difficult and has a lot of small steps, so a guide is needed to lead people through the process. This guide will show you every step in the process of disassembling a 3DS XL properly, since a few of the parts are a bit delicate. The replacement does not need any prior knowledge on technology to do. The process does require patience and carefulness.
Wat je nodig hebt
Use your fingers to carefully disconnect the small green rectangle (network board).
Use your fingers to disconnect the green rectangle (network board) from the small green cable.
Één andere persoon heeft deze handleiding voltooid.
