Inleiding
Battery having issues and need to be placed? This guide will take you through the steps necessary to have a new battery in your Nintendo 3DS XL in no time!
Gereedschap
Hold the device so that the cover is facing up.
Using a plastic opening tool, pry off the cover starting at the top right corner.
Hold the edge of the cover to ensure it does not reattach.
Look for the small section below the stylus compartment. Pry off the cover at that point if it is still attached.
Take off the cover of the device and set aside.
31 andere personen hebben deze handleiding voltooid.
4 Opmerkingen
Time estimate: 3 - 9 hours Difficulty: Very difficult ??????
More like 30-90 seconds, and that's if you have to search for a screwdriver.
It should be noted that the bottom three clips on the bottom of the backplate can’t just be snapped in, they need to be slipped in, so when removing the backplate, it should be tiled away from the system and then pulled up from the bottom, and those three clips on the bottom should be the first clips in when you’re putting it back together, sliding them in with the backplate at an angle, and then the rest of the clips just snap in.
Just did this. For reasmbly I recommend putting the bottom/lower part of the case on first before you screw it back on.
