Ga door naar hoofdinhoud
Nintendo 3DS XL 2015 Camera Replacement
Wat je nodig hebt
  1. Nintendo 3DS XL 2015 Camera Replacement, Battery: stap 1, afbeelding 1 van 1
    • Ensure your device is powered off before proceeding. Failure to do so may result in electrical shock or damage to the device.
    • Place the 3DS upside down. Remove the game card, headphones, charging cable, stylus, or anything else that may be connected to the device.
  2. Nintendo 3DS XL 2015 Camera Replacement: stap 2, afbeelding 1 van 1
    • Using a JIS #0 screwdriver, loosen the two black screws on the back.
    • The screws are held in place by captive washers and should not be completely removed.
  3. Nintendo 3DS XL 2015 Camera Replacement: stap 3, afbeelding 1 van 1
    • Once the screws are loosened, pry open the back cover.
  4. Nintendo 3DS XL 2015 Camera Replacement: stap 4, afbeelding 1 van 1
    • The battery is located on the left hand side of the 3DS - to remove, use the small gap located at the top-middle and pull up with a non metal pointed tool.
  5. Nintendo 3DS XL 2015 Camera Replacement, Motherboard: stap 5, afbeelding 1 van 1
    • Using a JIS #000 screwdriver, remove the six 6mm screws around the edges of the secondary cover.
  6. Nintendo 3DS XL 2015 Camera Replacement: stap 6, afbeelding 1 van 2 Nintendo 3DS XL 2015 Camera Replacement: stap 6, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers, carefully pop out the rubber bumpers located at the top side of the 3DS. Removing them will reveal another two 6mm screws. Remove these screws using a JIS #000 as well.
  7. Nintendo 3DS XL 2015 Camera Replacement: stap 7, afbeelding 1 van 3 Nintendo 3DS XL 2015 Camera Replacement: stap 7, afbeelding 2 van 3 Nintendo 3DS XL 2015 Camera Replacement: stap 7, afbeelding 3 van 3
    • To separate the cover, carefully lift it up and away from the hinges (in order to clear the headphone port), then pivot it towards the hinges to expose the circuit boards.
    • Don't fully remove the cover yet, or you may damage the delicate ribbon cable that still connects it to the motherboard.
  8. Nintendo 3DS XL 2015 Camera Replacement: stap 8, afbeelding 1 van 1
    • Use a pair of tweezers to lift away the two plugs that latch the L/R/ZL/ZR button ribbons to the motherboard. You can now remove the back cover completely and set it aside.
  9. Nintendo 3DS XL 2015 Camera Replacement: stap 9, afbeelding 1 van 1
    • Use tweezers to flip up the small, hinged locking flap in order to unlock the ZIF connector securing the circle pad ribbon.
    • Slide the ribbon out of the ZIF connector.
  10. Nintendo 3DS XL 2015 Camera Replacement: stap 10, afbeelding 1 van 1
    • Using a JIS #000 screwdriver, remove the two 8 mm screws securing the circle pad.
  11. Nintendo 3DS XL 2015 Camera Replacement: stap 11, afbeelding 1 van 1
    • Lift the circle pad casing upward to remove it. There will be some friction, but it should not require excessive force.
  12. Nintendo 3DS XL 2015 Camera Replacement: stap 12, afbeelding 1 van 1
    • Locate the gold terminal plug with a red cable at the top left of the motherboard. Using your fingers, carefully pull the plug straight upward to remove.
    • Use a pair of tweezers to disconnect the single ribbon connector.
    • Don't do what we did -- be very careful not to pull on the red cable.
  13. Nintendo 3DS XL 2015 Camera Replacement: stap 13, afbeelding 1 van 3 Nintendo 3DS XL 2015 Camera Replacement: stap 13, afbeelding 2 van 3 Nintendo 3DS XL 2015 Camera Replacement: stap 13, afbeelding 3 van 3
    • Using tweezers, gently pull the five marked ribbons out of the ZIF connectors along the sides of the motherboard.
    • These ZIF connectors are held in place by friction and do not have locks—lifting the flaps on these connectors will break them! Note that in some models the upper-most connector may have a lock.
    • Three of the ribbon connectors have plastic clamping flaps that cover the ribbon to prevent slippage. Use the tweezers to flip them up before ribbon removal.
    • When reassembling the device, be sure to flip the ZIF clamps back down.
    • While the SD card reader is shown as removed in this photo, it is optional for the removal of the motherboard.
  14. Nintendo 3DS XL 2015 Camera Replacement: stap 14, afbeelding 1 van 1
    • Using a JIS #000 screwdriver, remove six 4mm screws along the edges of the motherboard.
  15. Nintendo 3DS XL 2015 Camera Replacement: stap 15, afbeelding 1 van 2 Nintendo 3DS XL 2015 Camera Replacement: stap 15, afbeelding 2 van 2
    • Carefully pivot the motherboard 90 degrees toward the hinges to reveal two more ZIF connectors on the underside of the motherboard.
    • Both have latches that must be flipped up. The left, longer latch is black; the right, shorter one is white. Flip up the flaps, slide the ribbons out and remove the motherboard.
    • Note which way the ribbons slide into their connectors carefully, as they are different.
  16. Nintendo 3DS XL 2015 Camera Replacement, Top Display Casing: stap 16, afbeelding 1 van 2 Nintendo 3DS XL 2015 Camera Replacement, Top Display Casing: stap 16, afbeelding 2 van 2
    • Using a 1.5 flat head, remove the four red rubber stickers that are on the inside of the casing.
    • Underneath the rubber is a silver sticky
    • Using the PH00 screw driver, remove the screws.
  17. Nintendo 3DS XL 2015 Camera Replacement: stap 17, afbeelding 1 van 2 Nintendo 3DS XL 2015 Camera Replacement: stap 17, afbeelding 2 van 2
    • From the hinge, slide the outer portion of the top shell so that it separates from the inner portion.
    • This step was edited recently because the previous version was risky. It told people to use a spudger and slide it around the edges. DO NOT DO THIS!!! It will snap tabs off!
    • The casing will become loose, and just lift the casing off.
  18. Nintendo 3DS XL 2015 Camera Replacement, Camera: stap 18, afbeelding 1 van 2 Nintendo 3DS XL 2015 Camera Replacement, Camera: stap 18, afbeelding 2 van 2
    • The camera should be loose, just lift carefully.
    • the cable that is attached to it, should be easy to remove from the bottom half of the DS.
    • Make sure that you have followed the guide to remove the motherboard because this is how you unhook the cable for the camera.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ryan Butler
1.695 Reputatie
9 handleidingen geschreven
iFixit, Team 1-1, Weber Winter 2016 Lid van iFixit, Team 1-1, Weber Winter 2016
FIX-WEBER-W16S1G1
4 Leden
37 handleidingen geschreven
6 opmerkingen
This doesn't actually show how to get the new camera in, I managed to pull the cable of the old one out but I have no idea how to get the new one through the hinge cover wrapping surround the wires
reubengreen - Antwoord
In some youtube video I saw that guy rolled new camera ribbon cable and got it through the hinge cover.
Keränen Alexey -
A whole bunch of steps missing the end. First you have to release the hinge: Remove the circuit board that has the arrow keys (4 screws), remove two plastic pieces immediately above (one black square, when removed a transparent thin piece is visible.
Open hinge to near 180. Using probe or bent tweezers or stiff, thin item, push the hinge pin towards the middle through the narrow opening exposed when the plastic pieces were removed. When it touches the display it's far enough, you may have to slightly flex the hinge to release the pin.
You can now release the other side, with the flex cables going through it and the antenna cable. Feed the 3 flex cables into the slot in the plastic as you release the hinge; once it's clear you can pull them through.
Curl the camera cable (it was on top, and attached on the upper side of the corner of the mainboard) and pull it through the rung and hollow ring.
continues...
jesup - Antwoord
"missing at the end" :-)
jesup -
Now reverse with the new cable - curl it gently to get it into the hinge and through the ring, help pull through with tweezers. Now you can start reversing. Note that the hinge pin needs the screen to be open near 180 to slide back into place. Also be careful when reattaching ribbon cables - the display cable (bottom cable of the 3 in the hinge, the longest one) is easy to put in upside down. Take pictures when disassembling. (contacts for this one go down)
jesup - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 85
Afgelopen 30 dagen: 372
Altijd: 9,118
