Ga door naar hoofdinhoud
Nintendo 3DS Stylus Housing Replacement
Wat je nodig hebt
  1. Nintendo 3DS Stylus Housing Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Unscrew the four Phillips #00 screws along the top of the back cover.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    • The comments section is full of unlucky souls who will tell you that the screws here through step 4 will strip incredibly easily. Press down fairly hard, and go slow.
  2. Nintendo 3DS Stylus Housing Replacement: stap 2, afbeelding 1 van 2 Nintendo 3DS Stylus Housing Replacement: stap 2, afbeelding 2 van 2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Nintendo 3DS Stylus Housing Replacement, Battery: stap 3, afbeelding 1 van 3 Nintendo 3DS Stylus Housing Replacement, Battery: stap 3, afbeelding 2 van 3 Nintendo 3DS Stylus Housing Replacement, Battery: stap 3, afbeelding 3 van 3
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
  4. Nintendo 3DS Stylus Housing Replacement, Lower Case: stap 4, afbeelding 1 van 1
    • Remove the nine 6.3 mm black Phillips screws from the lower case.
    • These screws will strip very easily unless you use the correct size bit. Apply pressure to the screws while turning to avoid stripping them.
    • Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
  5. Nintendo 3DS Stylus Housing Replacement: stap 5, afbeelding 1 van 3 Nintendo 3DS Stylus Housing Replacement: stap 5, afbeelding 2 van 3 Nintendo 3DS Stylus Housing Replacement: stap 5, afbeelding 3 van 3
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
  6. Nintendo 3DS Stylus Housing Replacement, Stylus Housing: stap 6, afbeelding 1 van 1
    • Remove the stylus from the lower case.
  7. Nintendo 3DS Stylus Housing Replacement: stap 7, afbeelding 1 van 3 Nintendo 3DS Stylus Housing Replacement: stap 7, afbeelding 2 van 3 Nintendo 3DS Stylus Housing Replacement: stap 7, afbeelding 3 van 3
    • Remove the four 2.4 mm Phillips screws that secure the stylus housing to the lower case.
    • Use a plastic opening tool to pry the stylus housing up from the lower case.
    • Grab the stylus housing and remove it from the lower case.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
David Hodson
150.882 Reputatie
127 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 42
Altijd: 7,287
