Ga door naar hoofdinhoud
Nintendo 3DS SD Board Replacement
Alleen vereisten
Deze handleiding is alleen bedoeld als vereiste voor andere handleidingen. Het staat niet op zichzelf.
Wat je nodig hebt
  1. Nintendo 3DS SD Board Replacement, SD Board: stap 1, afbeelding 1 van 1
    • Remove the two 4.5 mm Phillips screws securing the SD board to the motherboard.
  2. Nintendo 3DS SD Board Replacement: stap 2, afbeelding 1 van 2 Nintendo 3DS SD Board Replacement: stap 2, afbeelding 2 van 2
    • Use the flat end of a spudger to pry the SD board ribbon cable connector off its socket on the motherboard.
  3. Nintendo 3DS SD Board Replacement: stap 3, afbeelding 1 van 3 Nintendo 3DS SD Board Replacement: stap 3, afbeelding 2 van 3 Nintendo 3DS SD Board Replacement: stap 3, afbeelding 3 van 3
    • Insert the flat end of a spudger between the SD board and the motherboard.
    • Pry up slowly to loosen the SD board from the RF shield underneath it. If you pry too quickly, you may tear the shield or break its solder points.
    • Run the spudger along the sides of the SD board to free it from the adhesive holding it in place.
    • Once completely freed, lift the SD board straight off the motherboard.
    be careful on this step, the sd card board is adhered to the rf shield below it, and bay result in the shield becoming bent as it is only soldered on one side. pry from the side of the board facing the cartridge slot.
    alex chargeer - Antwoord
    I didnt notice that and I broke the solders here :(
    Tony Greco -
    mine came off will this make the system not power on or make somthing not work? what do i do know?
    AppleTopic - Antwoord
    What did come off? the sd card reader board, or the shield mentioned in the above comment?
    Daniele Carminati -
    When putting it all back together, its easier to put the ribbon connector on before laying on the SD board.
    Pepper - Antwoord
Conclusie
David Hodson
150.455 Reputatie
127 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 232
