Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Can't turn your 3DS on or off? Your power button may be malfunctioning.
Wat je nodig hebt
Insert a plastic opening tool into the notch in the lower case above the battery.
Pry the battery up with the plastic opening tool.
Grab the top edge of the battery and lift it out of the lower case.
Remove the nine 6.3 mm black Phillips screws from the lower case.
Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
Remove the two 7.7 mm Phillips screws securing the back of the Circle Pad to the motherboard.
Remove the two 4.5 mm Phillips screws securing the SD board to the motherboard.
Insert the flat end of a spudger between the SD board and the motherboard.
Pry up slowly to loosen the SD board from the RF shield underneath it. If you pry too quickly, you may tear the shield or break its solder points.
Run the spudger along the sides of the SD board to free it from the adhesive holding it in place.
Once completely freed, lift the SD board straight off the motherboard.
Slide the flat end of a spudger under the corner of the Wi-Fi board, and lift it away from the motherboard.
Grasp the microphone ribbon cable near the microphone with a pair of tweezers.
Pull the microphone straight up out of the upper case.
