Ga door naar hoofdinhoud
Nintendo 3DS IR Board Replacement
Wat je nodig hebt
  1. Nintendo 3DS IR Board Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Unscrew the four Phillips #00 screws along the top of the back cover.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    • The comments section is full of unlucky souls who will tell you that the screws here through step 4 will strip incredibly easily. Press down fairly hard, and go slow.
  2. Nintendo 3DS IR Board Replacement: stap 2, afbeelding 1 van 2 Nintendo 3DS IR Board Replacement: stap 2, afbeelding 2 van 2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Nintendo 3DS IR Board Replacement, Battery: stap 3, afbeelding 1 van 3 Nintendo 3DS IR Board Replacement, Battery: stap 3, afbeelding 2 van 3 Nintendo 3DS IR Board Replacement, Battery: stap 3, afbeelding 3 van 3
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
  4. Nintendo 3DS IR Board Replacement, Lower Case: stap 4, afbeelding 1 van 1
    • Remove the nine 6.3 mm black Phillips screws from the lower case.
    • These screws will strip very easily unless you use the correct size bit. Apply pressure to the screws while turning to avoid stripping them.
    • Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
  5. Nintendo 3DS IR Board Replacement: stap 5, afbeelding 1 van 3 Nintendo 3DS IR Board Replacement: stap 5, afbeelding 2 van 3 Nintendo 3DS IR Board Replacement: stap 5, afbeelding 3 van 3
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
  6. Nintendo 3DS IR Board Replacement, IR Board: stap 6, afbeelding 1 van 3 Nintendo 3DS IR Board Replacement, IR Board: stap 6, afbeelding 2 van 3 Nintendo 3DS IR Board Replacement, IR Board: stap 6, afbeelding 3 van 3
    • Use the flat end of a spudger to lightly pry the IR board off the motherboard.
    • Grab the edges of the IR board with two fingers and lift it from the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
David Hodson
150.882 Reputatie
127 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 55
Altijd: 8,752
