Ga door naar hoofdinhoud
Nintendo 3DS Cartridge Reader Replacement
Wat je nodig hebt
  1. Nintendo 3DS Cartridge Reader Replacement, Cartridge Reader: stap 1, afbeelding 1 van 3 Nintendo 3DS Cartridge Reader Replacement, Cartridge Reader: stap 1, afbeelding 2 van 3 Nintendo 3DS Cartridge Reader Replacement, Cartridge Reader: stap 1, afbeelding 3 van 3
    • Carefully remove the 5 screws highlighted in the first photos using the 00 Philips screwdriver
    • carefully lift up the backplate upwards from the card slot as to not break the plastic clips
    • now that the second layer is exposed remove the battery as to not accidentally turn on the device or get a static shock
  2. Nintendo 3DS Cartridge Reader Replacement: stap 2, afbeelding 1 van 2 Nintendo 3DS Cartridge Reader Replacement: stap 2, afbeelding 2 van 2
    • remove all 10 screws inorder to access the third layer and the motherboard of the 3DS ( don't forget the one near the game card slot !)
    • carefully open up the next layer of the 3ds as to not rip any of the ribbon wires
    • leave screws to the side for later reconstruction
  3. Nintendo 3DS Cartridge Reader Replacement: stap 3, afbeelding 1 van 3 Nintendo 3DS Cartridge Reader Replacement: stap 3, afbeelding 2 van 3 Nintendo 3DS Cartridge Reader Replacement: stap 3, afbeelding 3 van 3
    • Now that all of the stuff is out of the way you will now solder the cartridge slot out
    • CAUTION: soldering iron can cause severe burns if not used properly, proceed with caution and have an adult in the room with you if underage
  4. Nintendo 3DS Cartridge Reader Replacement: stap 4, afbeelding 1 van 1
    • now that the game cartridge reader is out of the way lets get the new one in and line it up with the previous one and re-solder it using a soldering wire
    • as mentioned previously soldering iron can cause severe burns if not used properly, proceed with caution
  5. Nintendo 3DS Cartridge Reader Replacement: stap 5, afbeelding 1 van 1
    • Before closing off the device you will now use Isopropyl alcohol and a cue tip and clean the surrounding area so there is a good current and grip
    • If isopropyl alcohol is consumed it will cause irritation in the stomach and intestines
  6. Nintendo 3DS Cartridge Reader Replacement: stap 6, afbeelding 1 van 1
    • remember to use the correct screws when closing the back plate of the device. if you use the wrong one then it can screw all the way into the motherboard
    • don't forget about the tiny silver screw near the game card slot.
    • you will be using the same screws from steps 1 and 2 for the current step and step 7
  7. Nintendo 3DS Cartridge Reader Replacement: stap 7, afbeelding 1 van 1
    • make sure to close the back plate. if the back plate is not secures correctly and properly then it can cause any liquid or even dirt to enter and cause the battery to get ruined and the other inner components.
Conclusie
there are many steps that you will need to do carefully as well as tools that can cause harm but we hope that this guide has helped you get your device up and running. thank you for trusting in us.
Abraham Zapata
145 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 45
Afgelopen 30 dagen: 95
Altijd: 112
