Ga door naar hoofdinhoud
Nintendo 3DS 2015 SD Card Reader Replacement
Wat je nodig hebt
  1. Nintendo 3DS 2015 SD Card Reader Replacement, Battery: stap 1, afbeelding 1 van 1
    • Unscrew the two 3mm Phillips #1 head screws along the top edge of the device.
    • The screws on the back panel strip easily. Go slowly and press down firmly.
    • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
  2. Nintendo 3DS 2015 SD Card Reader Replacement: stap 2, afbeelding 1 van 2 Nintendo 3DS 2015 SD Card Reader Replacement: stap 2, afbeelding 2 van 2
    • Pull the top corner tabs of the front face plate outward and towards you.
    • Pull the faceplate up and out of the slots at the bottom of the device.
    • Set aside the back faceplate.
  3. Nintendo 3DS 2015 SD Card Reader Replacement: stap 3, afbeelding 1 van 3 Nintendo 3DS 2015 SD Card Reader Replacement: stap 3, afbeelding 2 van 3 Nintendo 3DS 2015 SD Card Reader Replacement: stap 3, afbeelding 3 van 3
    • Insert a plastic opening tool into the notch at the top of the battery.
    • Pry the battery up with the plastic opening tool.
  4. Nintendo 3DS 2015 SD Card Reader Replacement, SD Card Reader: stap 4, afbeelding 1 van 1
    • Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
    • The bottom of the SD card reader should slightly pop out after removing the screws.
  5. Nintendo 3DS 2015 SD Card Reader Replacement: stap 5, afbeelding 1 van 1
    • Pull the SD card reader from the edge with two holes gently to free the tab at the top of the SD card reader.
    • Don't completely pull the SD card out of the device yet. There is a ribbon cable connected under the SD card reader.
    • Reorient the device so that the power jack faces you.
  6. Nintendo 3DS 2015 SD Card Reader Replacement: stap 6, afbeelding 1 van 2 Nintendo 3DS 2015 SD Card Reader Replacement: stap 6, afbeelding 2 van 2
    • Lift the SD card reader gently.
    • Use a plastic opening tool to pry the SD card ribbon cable off the socket on the motherboard.
    • Lift the SD card reader out off of the lower casing.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Tyler Starr
1.758 Reputatie
7 handleidingen geschreven
Cal Poly, Team 4-6, Livingston Fall 2016 Lid van Cal Poly, Team 4-6, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G6
4 Leden
45 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 46
Afgelopen 30 dagen: 277
Altijd: 8,799
