Ga door naar hoofdinhoud
Nintendo 2DS Battery Replacement
Wat je nodig hebt
  1. Nintendo 2DS Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the two Phillips captive screws securing the upper rear panel.
    • The captive screws will not completely detach from the back panel.
  2. Nintendo 2DS Battery Replacement: stap 2, afbeelding 1 van 2 Nintendo 2DS Battery Replacement: stap 2, afbeelding 2 van 2
    • Hinge the upper rear panel upwards and outwards to remove it.
  3. Nintendo 2DS Battery Replacement: stap 3, afbeelding 1 van 3 Nintendo 2DS Battery Replacement: stap 3, afbeelding 2 van 3 Nintendo 2DS Battery Replacement: stap 3, afbeelding 3 van 3
    • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
Conclusie
38 andere personen hebben deze handleiding voltooid.
Fina Beauchamp
3.150 Reputatie
6 handleidingen geschreven
Cal Poly, Team 70-1, Forte Winter 2015 Lid van Cal Poly, Team 70-1, Forte Winter 2015
CPSU-FORTE-W15S70G1
4 Leden
35 handleidingen geschreven
5 opmerkingen
The only thing I was trying to figure out is if the bezel came up with the panel, and it’s not clear from these photos. For the record, it does not.
francis deible - Antwoord
This didnt help my problem
Artemy Matveev - Antwoord
maybe its because you did not plug the battery correctly matthew
Ludovic Chartrain - Antwoord
or maybe its just not working ludovic 🫡
Natalia Rabago -
Who knows, will the same battery, instead of 1300mah in original, 2000mah in 'fake' works with 2DS?
Anton Kornilov - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 36
Afgelopen 7 dagen: 206
Afgelopen 30 dagen: 908
Altijd: 49,107
