Ga door naar hoofdinhoud
Ninja Ultima BL810 Handle Replacement
Wat je nodig hebt
  1. Ninja Ultima BL810 Handle Replacement, Handle: stap 1, afbeelding 1 van 1
    • Remove five Phillips #2 9mm screws on the bottom of the blender.
  2. Ninja Ultima BL810 Handle Replacement: stap 2, afbeelding 1 van 2 Ninja Ultima BL810 Handle Replacement: stap 2, afbeelding 2 van 2
    • Use a metal spudger to pop out the upper layer of the handle.
    • Pull the upper plastic layer off the handle.
  3. Ninja Ultima BL810 Handle Replacement: stap 3, afbeelding 1 van 1
    • Unhook the latches from each side of the top portion of the handle with the metal spudger.
  4. Ninja Ultima BL810 Handle Replacement: stap 4, afbeelding 1 van 2 Ninja Ultima BL810 Handle Replacement: stap 4, afbeelding 2 van 2
    • Pull the black handle off of the pitcher.
    • Don't pull to hard or you may break the handle off of the base.
    • Once it disconnected, pull base and handle down in order to remove it from the pitcher.
Conclusie
Donald Syracuse
213 Reputatie
2 handleidingen geschreven
Cal Poly, Team S9-G4, Banghart Fall 2017 Lid van Cal Poly, Team S9-G4, Banghart Fall 2017
CPSU-BANGHART-F17S9G4
4 Leden
6 handleidingen geschreven
3 opmerkingen
Hi there,
Was there a spring when you did this? I took my apart and a spring popped out but I don’t know where it goes? I contacts Ninja and they don’t know exactly where it goes. Can you provide me with some assistance?
sherahisrael12 - Antwoord
Hi! I have a Ninja and found this page encouraging although not the same model as mine. I watched a video of a woman prying it off and I saw something go flying (which I knew was the spring).
The answer to your question is that it goes in the bottom of the handle vertically with the bottom in a little cylindrical divot on the outer black plastic part. I'm washing it right now and I'll post up pictures soon. You posted this years ago so if you reply right away I'll get the pics posted sooner. I would have looked into all this sooner and had an answer for you back in 2019 but I didn't need to clean it until this year so I had no idea anyone was unsure about the disassembly and spring placement. I hope you already figured it out. If not let me know.
Professor Brown -
I have a model CT680SS btw which only requires the removal of two screws. Ok, I tried to copy and paste and no go on showing any pics. I don't know how to attach pictures here so if anyone knows, please reply to this post. The could put them on a picture hosting site but that's a pita that I wasn't really interested in unless there someone really wants them.
Professor Brown - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 63
Altijd: 5,746
