Ga door naar hoofdinhoud
Ninja NJ600 Fan Replacement
Wat je nodig hebt
  1. Ninja NJ600 Fan Replacement, Blender Base Cover: stap 1, afbeelding 1 van 2 Ninja NJ600 Fan Replacement, Blender Base Cover: stap 1, afbeelding 2 van 2
    • Remove the five screws (13mm long, 6mm head diameter) using a Phillips #2 screwdriver.
  2. Ninja NJ600 Fan Replacement: stap 2, afbeelding 1 van 2 Ninja NJ600 Fan Replacement: stap 2, afbeelding 2 van 2
    • Without removing any screws, you can pull the 2nd layer free from the base. Do this now and set it down gently next to the base.
    • The power cord runs through a hole in the side of this layer. Squeeze the cord and pull it through the hole to separate the layer from the cord.
  3. Ninja NJ600 Fan Replacement: stap 3, afbeelding 1 van 3 Ninja NJ600 Fan Replacement: stap 3, afbeelding 2 van 3 Ninja NJ600 Fan Replacement: stap 3, afbeelding 3 van 3
    • Using the Phillips #2 screwdriver, remove these six screws (13mm long, 6mm head diameter). Then carefully remove this layer, and rest it next to the blender base.
    • Be careful not to damage the two wires that are keeping this third layer attached to the base.
  4. Ninja NJ600 Fan Replacement, Fan: stap 4, afbeelding 1 van 1
    • Hold the fan steady and use a wrench or pliers to remove the nut in the image.
    • The fan is sharp. Use caution when handling with bare hands.
    • A towel or gloves may be useful when holding the fan for this step.
  5. Ninja NJ600 Fan Replacement: stap 5, afbeelding 1 van 1
    • Hold the fan and use the flathead 4.0 screwdriver to loosen the washer.
    • The fan is sharp, use caution when handling with bare hands.
    • You may use a towel or gloves to avoid handling the fan with your bare hands.
  6. Ninja NJ600 Fan Replacement: stap 6, afbeelding 1 van 2 Ninja NJ600 Fan Replacement: stap 6, afbeelding 2 van 2
    • Slide the washer and fan off of the screw.
Conclusie
Ryan Heller
107 Reputatie
1 Handleiding geschreven
Cal Poly, Team 24-2, Lancaster Spring 2015 Lid van Cal Poly, Team 24-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G2
4 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 17
Altijd: 1,531
