Inleiding
This guide will show how to replace the circuit board in your Ninja Professional Blender, in the event that it stops working. The removal process requires the removal of four screws and the desolder of five components.
Wat je nodig hebt
Remove the five screws (13mm long, 6mm head diameter) using a Phillips #2 screwdriver.
Remove these four screws (10mm long, 5mm head diameter) using a Phillips #2 screwdriver.
To reassemble your device, follow these instructions in reverse order, but solder the wires back to the board.
4Gids Commentaar
Where can I buy de circuito board?
Where can i buy the circuit board ?
