Ga door naar hoofdinhoud
Ninja Mega Kitchen System BL770 Cooling Fan Replacement
Wat je nodig hebt
  1. Ninja Mega Kitchen System BL770 Cooling Fan Replacement, Circuit Base: stap 1, afbeelding 1 van 2 Ninja Mega Kitchen System BL770 Cooling Fan Replacement, Circuit Base: stap 1, afbeelding 2 van 2
    • Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
    • Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
  2. Ninja Mega Kitchen System BL770 Cooling Fan Replacement: stap 2, afbeelding 1 van 1
    • Carefully remove the second layer from the base. You will not need a screwdriver for this step.
  3. Ninja Mega Kitchen System BL770 Cooling Fan Replacement: stap 3, afbeelding 1 van 3 Ninja Mega Kitchen System BL770 Cooling Fan Replacement: stap 3, afbeelding 2 van 3 Ninja Mega Kitchen System BL770 Cooling Fan Replacement: stap 3, afbeelding 3 van 3
    • Remove the 2 screws (13mm, 6mm head) connected to the plastic piece holding down the power cord.
    • Then remove the additional 4 screws (13mm, 6mm head) and 2 screws (11mm, 5mm head) securing the base.
    • Carefully lift the base up from the rest of the blender.
  4. Ninja Mega Kitchen System BL770 Cooling Fan Replacement: stap 4, afbeelding 1 van 1
    • Remove 4 screws (11mm, 4mm head) connecting the circuit board to the base.
  5. Ninja Mega Kitchen System BL770 Cooling Fan Replacement, Cooling Fan: stap 5, afbeelding 1 van 2 Ninja Mega Kitchen System BL770 Cooling Fan Replacement, Cooling Fan: stap 5, afbeelding 2 van 2
    • Using caution, hold the fan steady and use a wrench or pliers to remove the nut securing the fan.
    • Loosen the washer with a flathead screwdriver, then remove the fan and replace with a new one.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tommee Walker
823 Reputatie
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 777
