Inleiding
The water heating element is a resistive coiled wire that boils the water used in brews. This guide describes how to replace the heating element.
Wat je nodig hebt
Unscrew the T-10 screws from the bottom cover of the machine, and remove that bottom cover.
Using wire strippers, strip the cut wires from your coffee machine near their cut ends to expose 2 cm of metal conductor from each.
Use a similar procedure to strip the wires from your replacement heating element. Using wire strippers, expose 2 cm of metal conductor from the ends of the wires.
Prepare two crimp connectors by filling them with dielectric grease.
Use a crimp connector to connect a stripped end of the wire leading from the replacement heating element to the stripped end of the corresponding wire from the coffee maker.
Using a second crimp connector, repeat for the remaining pair of stripped wires.
Using the appropriate crimping tool, crimp the connectors.
To finish reassembling your device, follow steps 2-7 in reverse order.
2 opmerkingen
I need a element for a CM401 model, any help?. gene@wholedamarea.com
