Inleiding
This is very similar to replacing the tubes in the device, which is show in another repair guide created for the ninja coffee bar. Be very careful with the screws because they are very small. We would suggest the magnetic mat provided by iFixit so you don't lose the screws. Just like the tube repair guide, be careful removing the protective plate because there are a lot of wires that can not be disconnected. Also, make sure to take some pictures of the wiring just incase some of them do slip loose.
Wat je nodig hebt
Unscrew eight 6mm screws with Phillips head #1 screwdriver
Remove bottom cover
2 opmerkingen
Where can I get the replacement water valve?
Anyone have a source for the valve?
