Inleiding
If your normally piping hot cup of coffee is coming out at room temperature then the water heater may be to blame. This replacement involves removing a number of small screws so it may be a good idea to have the iFixit magnet pad nearby. Follow this guide to replace your device’s water heater and restore heat to your Ninja Coffee Bar.
Wat je nodig hebt
Remove the eight 6 mm screws using the Phillips #1 screwdriver.
Remove the bottom cover.
Unscrew the four 6mm #1 Phillips head screws from the underside of the basket area.
Remove the single 6mm #1 Phillips-head screw from the side of the unit.
