Ga door naar hoofdinhoud
Ninja Coffee Bar® Single-Serve System Water Heater Replacement
Wat je nodig hebt
  1. Ninja Coffee Bar® Single-Serve System Water Heater Replacement, Valve Tubes: stap 1, afbeelding 1 van 2 Ninja Coffee Bar® Single-Serve System Water Heater Replacement, Valve Tubes: stap 1, afbeelding 2 van 2
    • Remove the eight 6 mm screws using the Phillips #1 screwdriver.
    • Remove the bottom cover.
  2. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: stap 2, afbeelding 1 van 1
    • Remove the three 6 mm screws with the Phillips #1 screwdriver.
    • Remove the plastic cover.
  3. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: stap 3, afbeelding 1 van 1
    • Detach the valve tubes from the valve by squeezing the pins and pulling them away from the valve.
  4. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: stap 4, afbeelding 1 van 1
    • Detach the valve tubes from the device by pinching the pins and sliding the valve tubes off.
  5. Ninja Coffee Bar® Single-Serve System Water Heater Replacement, Water Heater: stap 5, afbeelding 1 van 2 Ninja Coffee Bar® Single-Serve System Water Heater Replacement, Water Heater: stap 5, afbeelding 2 van 2
    • Unscrew the four 6mm #1 Phillips head screws from the underside of the basket area.
    • Remove the single 6mm #1 Phillips-head screw from the side of the unit.
  6. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: stap 6, afbeelding 1 van 2 Ninja Coffee Bar® Single-Serve System Water Heater Replacement: stap 6, afbeelding 2 van 2
    • Slowly pry the upper cover away from the unit on top of the brew basket, and near the base of the water reservoir along the side of the upper cover.
  7. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: stap 7, afbeelding 1 van 1
    • Separate hose from upper nozzle by squeezing the clamp and pulling the hose down slightly.
  8. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: stap 8, afbeelding 1 van 2 Ninja Coffee Bar® Single-Serve System Water Heater Replacement: stap 8, afbeelding 2 van 2
    • Using a #1 Phillips head screwdriver with an extension, remove three 6mm screws holding the heater to the unit.
  9. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: stap 9, afbeelding 1 van 1
    • Remove heater from unit.
  10. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: stap 10, afbeelding 1 van 2 Ninja Coffee Bar® Single-Serve System Water Heater Replacement: stap 10, afbeelding 2 van 2
    • Squeeze clip and separate signal wiring.
    • Using wire stripper/crimping tool, uncrimp wiring connectors
    • Wiring connectors are sealed together making them difficult to disconnect. Cutting and rewiring should be considered.
Conclusie
CJ Berg
444 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 Lid van UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G4
3 Leden
5 handleidingen geschreven
Één opmerking
Where can I buy the water heater?
lrstorey1 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 1,067
