Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove four 6mm #1 Phillips head screws from under the basket area.
Remove the single 6mm #1 Phillips head screw from the side of the unit.
Gently pry the upper cover off the unit above the brew basket and above the water reservoir base and along the side of the upper cover.
Remove the single 6mm #1 Phillips head screw from the top of the unit. (The two smaller screws should remain attached.)
Using an extension, remove the two 6mm Phillips head screws from the side of the frother motor pivot.
Pinch power connector and pull lighly to separate.
Pull motor straight up to separate from unit.
Één opmerking
Awesome write-up. But does anyone know where a replacement frother arm can be purchased?
