Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
If your frother unit is no longer providing you with delicious, foamy drinks then it may be time to replace the frother unit on your device. Use this guide to replace your frother and reclaim the ability to brew up specialty drinks with your Ninja Single Serve Coffee System.
Onderdelen
Geen onderdelen opgegeven.
  1. Remove four 6mm #1 Phillips head screws from under the basket area. Remove the single 6mm #1 Phillips head screw from the side of the unit.
    • Remove four 6mm #1 Phillips head screws from under the basket area.
    • Remove the single 6mm #1 Phillips head screw from the side of the unit.
  2. Gently pry the upper cover off the unit  above the brew basket and  above the water reservoir base and along the side of the upper cover. Gently pry the upper cover off the unit  above the brew basket and  above the water reservoir base and along the side of the upper cover.
    • Gently pry the upper cover off the unit above the brew basket and above the water reservoir base and along the side of the upper cover.
  3. Remove the single 6mm #1 Phillips head screw from the top of the unit. (The two smaller screws should remain attached.) Using an extension, remove the two 6mm Phillips head screws from the side of the frother motor pivot.
    • Remove the single 6mm #1 Phillips head screw from the top of the unit. (The two smaller screws should remain attached.)
    • Using an extension, remove the two 6mm Phillips head screws from the side of the frother motor pivot.
  4. Pinch power connector and pull lighly to separate. Pull motor straight up to separate from unit. Pull motor straight up to separate from unit.
    • Pinch power connector and pull lighly to separate.
    • Pull motor straight up to separate from unit.
Conclusie
CJ Berg
444 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 Lid van UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G4
3 Leden
5 handleidingen geschreven
Één commentaar
Awesome write-up. But does anyone know where a replacement frother arm can be purchased?
clarkwolfe - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 22
Altijd: 573
