Ga door naar hoofdinhoud
Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement
Wat je nodig hebt
  1. Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement, Drip Stop Toggle and Brew Basket: stap 1, afbeelding 1 van 1
    • Slide the brew baskets to the open position.
  2. Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: stap 2, afbeelding 1 van 1
    • Remove three 6mm screws with Phillips head screw driver.
  3. Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: stap 3, afbeelding 1 van 3 Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: stap 3, afbeelding 2 van 3 Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Using needle nose tweezers, push the bottom of the pin up from behind the brew basket
    • Pull the pin out.
  4. Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: stap 4, afbeelding 1 van 1
    • Remove brew basket from swinging basket holder
  5. Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: stap 5, afbeelding 1 van 2 Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: stap 5, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove one 6mm screw from the drip stop toggle.
    • Remove the drip stop toggle.
Conclusie
Naser Aldousari
310 Reputatie
3 handleidingen geschreven
USF Tampa, Team S13-G69, Cagle Fall 2017 Lid van USF Tampa, Team S13-G69, Cagle Fall 2017
USFT-CAGLE-F17S13G69
4 Leden
3 opmerkingen
Can you provide more detail regarding the small spring that you provide the warning for? The one that needs to stay in place. If it does fall out, how can not be fixed or rather where does not go?
Dani - Antwoord
Agree! The spring NEEDS to be resting vertically in between the two clips, in my case, these have worn and the spring came out of seat. It needed to be refastened and the five beeps, “of death” have disappeared and my coffeepot functions again!
Marcus Martinez - Antwoord
* this works on the ninja coffee bar larger system as well
Marcus Martinez -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 45
Altijd: 6,967
