Ga door naar hoofdinhoud
Ninja Coffee Bar® Single-Serve System Frother Replacement
Wat je nodig hebt
  1. Ninja Coffee Bar® Single-Serve System Frother Replacement, Frother: stap 1, afbeelding 1 van 2 Ninja Coffee Bar® Single-Serve System Frother Replacement, Frother: stap 1, afbeelding 2 van 2
    • Remove four 6mm #1 Phillips head screws from under the basket area.
    • Remove the single 6mm #1 Phillips head screw from the side of the unit.
  2. Ninja Coffee Bar® Single-Serve System Frother Replacement: stap 2, afbeelding 1 van 2 Ninja Coffee Bar® Single-Serve System Frother Replacement: stap 2, afbeelding 2 van 2
    • Gently pry the upper cover off the unit above the brew basket and above the water reservoir base and along the side of the upper cover.
  3. Ninja Coffee Bar® Single-Serve System Frother Replacement: stap 3, afbeelding 1 van 2 Ninja Coffee Bar® Single-Serve System Frother Replacement: stap 3, afbeelding 2 van 2
    • Remove the single 6mm #1 Phillips head screw from the top of the unit. (The two smaller screws should remain attached.)
    • Using an extension, remove the two 6mm Phillips head screws from the side of the frother motor pivot.
  4. Ninja Coffee Bar® Single-Serve System Frother Replacement: stap 4, afbeelding 1 van 3 Ninja Coffee Bar® Single-Serve System Frother Replacement: stap 4, afbeelding 2 van 3 Ninja Coffee Bar® Single-Serve System Frother Replacement: stap 4, afbeelding 3 van 3
    • Pinch power connector and pull lighly to separate.
    • Pull motor straight up to separate from unit.
Conclusie
CJ Berg
444 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 Lid van UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G4
3 Leden
5 handleidingen geschreven
Één opmerking
Awesome write-up. But does anyone know where a replacement frother arm can be purchased?
clarkwolfe - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 21
Altijd: 1,496
