Inleiding
If you are having trouble mounting the lens and you are sure you have the correct lens type (see the camera manual for types of lenses that can be used), then use this guide to assist with replacing the lens mount.
Onderdelen
Geen onderdelen nodig.
  1. Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
    • Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
  2. Remove lens mount from the camera.
    • Remove lens mount from the camera.
    • Be careful not to lose any of the three loose pieces that are under the lens mount.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Zachary Phillips
205 Reputatie
5 handleidingen geschreven
Cal Poly, Team 25-26, Garner Spring 2011 Lid van Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 Leden
7 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 3
Afgelopen 30 Dagen: 20
Altijd: 4,567
