Inleiding
If there is a power problem, you may need to reattach wires to the battery compartment or replace it completely. If the problem is Corrosion, just see the guide on corrosion.
    • In this guide we will be referring to 'left' and 'right' as though the camera's front (the part that says Nikon) is facing you.
    • Unscrew the large metal screw on the left side using a quarter and remove the battery cover.(Picture not available)
  1. Use a 00 Phillips head screwdriver to remove the small screw on the far left of the battery compartment.
    • Use a 00 Phillips head screwdriver to remove the small screw on the far left of the battery compartment.
  2. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  3. Pull up on the tab to remove the batteries.
    • Pull up on the tab to remove the batteries.
    • Note: The batteries will probably fall out of their holder.
  4. Use a 00 Phillips head screwdriver to remove the four screws from inside the case.
    • Use a 00 Phillips head screwdriver to remove the four screws from inside the case.
  5. Remove the battery compartment from the camera.
    • Remove the battery compartment from the camera.
    • Note: On some models, the compartment is soldered in by the wires shown. If so you will need to desolder them.
Conclusie
Zachary Phillips
205 Reputatie
5 handleidingen geschreven
Cal Poly, Team 25-26, Garner Spring 2011 Lid van Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 Leden
7 handleidingen geschreven
Één commentaar
Hey, i lost the bracket… do u guys have any idea where could i get one?
David mate - Antwoord
Weergavestatistieken:
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 19
Afgelopen 30 Dagen: 88
Altijd: 10,069
