Inleiding
Prerequisite Only
Wat je nodig hebt
Using a PH00 screwdriver, remove the two 5.3 mm Phillips screws from the flash casing.
Use a plastic opening tool and carefully pry open the top casing of the flash.
Then, lift off the top casing of the flash.
Bijna klaar!
Conclusie
