Ga door naar hoofdinhoud
Nikon D90 Rear Display Buttons Replacement
Wat je nodig hebt
  1. Nikon D90 Rear Display Buttons Replacement, Removing Casing Screws: stap 1, afbeelding 1 van 2 Nikon D90 Rear Display Buttons Replacement, Removing Casing Screws: stap 1, afbeelding 2 van 2
    • Locate the screws on both sides of the camera.
    • Remove the four 6.3 mm Phillips screws using a PH00 screwdriver.
    • Be careful not to strip the screws.
  2. Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: stap 2, afbeelding 1 van 3 Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: stap 2, afbeelding 2 van 3 Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: stap 2, afbeelding 3 van 3
    • Use a plastic opening tool to separate the rear case from the camera.
  3. Nikon D90 Rear Display Buttons Replacement, Disconnecting the Ribbon Cables: stap 3, afbeelding 1 van 2 Nikon D90 Rear Display Buttons Replacement, Disconnecting the Ribbon Cables: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • After, remove the two orange ribbon connectors attached to the interior of the camera with tweezers.
    • Make sure to remove the ribbon cables carefully from the connectors to avoid damaging the camera.
  4. Nikon D90 Rear Display Buttons Replacement, Removing the Screws from the Rear Casing: stap 4, afbeelding 1 van 2 Nikon D90 Rear Display Buttons Replacement, Removing the Screws from the Rear Casing: stap 4, afbeelding 2 van 2
    • Remove the screws from the back assembly with a Phillips (PH00) head screwdriver.
    • Remove the ten 5.3 mm Phillips screws.
    • Remove the three 4.3 mm Phillips screws.
  5. Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: stap 5, afbeelding 1 van 3 Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: stap 5, afbeelding 2 van 3 Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: stap 5, afbeelding 3 van 3
    • Use a plastic opening tool to separate the LCD and metal plates from the casing.
  6. Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: stap 6, afbeelding 1 van 3 Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: stap 6, afbeelding 2 van 3 Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: stap 6, afbeelding 3 van 3
    • Use a plastic opening tool to separate the buttons from the casing.
    • Remove the 4.3 mm Phillips screw from the knob using a PH00 screwdriver.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
jonothon cawley
354 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 1-7, Duarte Fall 2014 Lid van UMass Dartmouth, Team 1-7, Duarte Fall 2014
UMASSD-DUARTE-F14S1G7
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 2,603
