Ga door naar hoofdinhoud
Inleiding
The spring of the camera flash can sometimes wear out and needs to be replaced. This guide shows how to replace the spring within the hinge of the camera flash. Be careful not to strip any screws when disassembling the camera.
Onderdelen
Geen onderdelen opgegeven.
  1. Use a plastic opening tool to lift up the flash. Use a plastic opening tool to lift up the flash. Use a plastic opening tool to lift up the flash.
    • Use a plastic opening tool to lift up the flash.
  2. Using a PH00 screwdriver, remove the two 5.3 mm Phillips screws from the flash casing. Be careful not to strip the screw heads.
    • Using a PH00 screwdriver, remove the two 5.3 mm Phillips screws from the flash casing.
    • Be careful not to strip the screw heads.
  3. Use a plastic opening tool and carefully pry open the top casing of the flash. Then, lift off the top casing of the flash. Then, lift off the top casing of the flash.
    • Use a plastic opening tool and carefully pry open the top casing of the flash.
    • Then, lift off the top casing of the flash.
  4. Using a PH00 screwdriver, loosen the 3.3 mm Phillips screw from the spring. Using a PH00 screwdriver, loosen the 3.3 mm Phillips screw from the spring.
    • Using a PH00 screwdriver, loosen the 3.3 mm Phillips screw from the spring.
  5. Use a plastic opening tool and carefully pry up the spring arm. Doing this with release the pressure of the spring.
    • Use a plastic opening tool and carefully pry up the spring arm.
    • Doing this with release the pressure of the spring.
  6. Finish removing the screw holding the spring in place. The spring can now be removed and replaced.
    • Finish removing the screw holding the spring in place.
    • The spring can now be removed and replaced.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Matthew Grota
560 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 1-7, Duarte Fall 2014 Lid van UMass Dartmouth, Team 1-7, Duarte Fall 2014
UMASSD-DUARTE-F14S1G7
3 Leden
6 handleidingen geschreven
Één commentaar
These are great tutorials,
I was looking for one on how to fix the pop up flash not locking down,
It was bought second hand and dropped on the logo,
The front panel needed to be replaced,
Now for the Flash that is constantly up.
Any links? jjryzler@gmail.com
Ryad Arlan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 27
Altijd: 3,223
