Inleiding
The spring of the camera flash can sometimes wear out and needs to be replaced. This guide shows how to replace the spring within the hinge of the camera flash. Be careful not to strip any screws when disassembling the camera.
Wat je nodig hebt
Using a PH00 screwdriver, remove the two 5.3 mm Phillips screws from the flash casing.
Use a plastic opening tool and carefully pry open the top casing of the flash.
Then, lift off the top casing of the flash.
Using a PH00 screwdriver, loosen the 3.3 mm Phillips screw from the spring.
Use a plastic opening tool and carefully pry up the spring arm.
Finish removing the screw holding the spring in place.
The spring can now be removed and replaced.
Één andere persoon heeft deze handleiding voltooid.
2Gids Commentaar
These are great tutorials,
I was looking for one on how to fix the pop up flash not locking down,
It was bought second hand and dropped on the logo,
The front panel needed to be replaced,
Now for the Flash that is constantly up.
Any links? jjryzler@gmail.com
My flash won't stay down. I think the piece that clips in to keep it closed may have broken. Is there a way to fix?
