Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
With a few simple tools and parts, this guide will help you replace your broken or burnt out bulb on the Nikon D90 camera. Be careful not to strip the screws as you disassemble the camera. In addition, be careful not to break the bulb or cut yourself on a broken bulb while you are disassembling the camera.
  1. Use a plastic opening tool to lift up the flash. Use a plastic opening tool to lift up the flash. Use a plastic opening tool to lift up the flash.
    • Use a plastic opening tool to lift up the flash.
  2. Using a PH00 screwdriver, remove the two 5.3 mm Phillips screws from the flash casing. Be careful not to strip the screw heads.
    • Using a PH00 screwdriver, remove the two 5.3 mm Phillips screws from the flash casing.
    • Be careful not to strip the screw heads.
  3. SLA DE UPGRADE OVER
    Bespaar door het te repareren met een alles-in-één kit.
    Koop iPhone-reparatiekits
    SLA DE UPGRADE OVER
  4. Use a plastic opening tool and carefully pry open the top casing of the flash. Then, lift off the top casing of the flash. Then, lift off the top casing of the flash.
    • Use a plastic opening tool and carefully pry open the top casing of the flash.
    • Then, lift off the top casing of the flash.
  5. Carefully unclip the bulb casing from the plastic casing using tweezers. Remove the black and white tape on the bulb casing.
    • Carefully unclip the bulb casing from the plastic casing using tweezers.
    • Remove the black and white tape on the bulb casing.
    • This tape is what holds the wires and bulb in place.
  6. Remove the rubber stopper on the left and right side of the bulb. Separate the rubber stopper from the white and black tape. The bulb can now be slid out and replaced.
    • Remove the rubber stopper on the left and right side of the bulb.
    • Separate the rubber stopper from the white and black tape.
    • The bulb can now be slid out and replaced.
    • Be careful not to break the bulb or cut yourself on the broken bulb.
Conclusie
8 andere personen hebben deze handleiding voltooid.
jonothon cawley
324 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 1-7, Duarte Fall 2014 Lid van UMass Dartmouth, Team 1-7, Duarte Fall 2014
UMASSD-DUARTE-F14S1G7
3 Leden
6 handleidingen geschreven
thanks for instruction…………really helpfull
hebi - Antwoord
Hi guys do you know where to get this bulb?please help
Martin Mitter - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 26
Altijd: 5,623
