Ga door naar hoofdinhoud
Inleiding
Excessive use sometimes causes certain ports, such as the AV Port, to cease normal function. This guide explains how to remove the main board from a Nikon D80 camera. For safety purposes, please remove the battery before working with any electronic components.
Please note that this guide requires soldering. For more information on how to solder and desolder connections, please visit this guide.
Onderdelen
Geen onderdelen opgegeven.
  1. Nikon D80 Main Board Replacement, Main Board: stap 1, afbeelding 1 van 2 Nikon D80 Main Board Replacement, Main Board: stap 1, afbeelding 2 van 2
    • Using a Phillips #00 screwdriver, remove the four 6.2 mm screws from the left and right sides of the outer cover.
  2. Nikon D80 Main Board Replacement: stap 2, afbeelding 1 van 3 Nikon D80 Main Board Replacement: stap 2, afbeelding 2 van 3 Nikon D80 Main Board Replacement: stap 2, afbeelding 3 van 3
    • Use tweezers to gently flip the small locking flap of the zero force insertion connector up.
    • Pull the orange connector cable out of the zero force insertion connector using the tweezers.
    • Remove the back cover.
  3. Nikon D80 Main Board Replacement: stap 3, afbeelding 1 van 3 Nikon D80 Main Board Replacement: stap 3, afbeelding 2 van 3 Nikon D80 Main Board Replacement: stap 3, afbeelding 3 van 3
    • Use a Phillips #00 screwdriver to remove the six 3.7 mm screws.
    • Remove the back plate that covers the main board.
  4. Nikon D80 Main Board Replacement: stap 4, afbeelding 1 van 2 Nikon D80 Main Board Replacement: stap 4, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to unscrew the 2.3 mm screw.
  5. Nikon D80 Main Board Replacement: stap 5, afbeelding 1 van 1
    • Use tweezers to gently flip the small locking flaps of the zero force insertion connectors up.
    • Pull the bottom orange connector cable out of the zero force insertion connector using the tweezers.
    • Pull the top orange connector cable out of the zero force insertion connector using the tweezers.
    • Remove the ribbon cables by gently pulling them away from the no-fuss ribbon cable connectors.
    • Disconnect the main board from the two ports on the left by pulling the main board to the right.
  6. Nikon D80 Main Board Replacement: stap 6, afbeelding 1 van 3 Nikon D80 Main Board Replacement: stap 6, afbeelding 2 van 3 Nikon D80 Main Board Replacement: stap 6, afbeelding 3 van 3
    • Using the soldering iron, disconnect the four wires soldered to the main board.
    • For more information on how to solder and desolder connections, please visit this guide.
    • Be careful when using the hot soldering iron. Move the ribbon cable out of the way as well; it is easy to burn it or yourself when using the iron.
    • Remove the main board.
Conclusie
Sara Martin
512 Reputatie
4 handleidingen geschreven
USF Tampa, Team S1-G1, Leahy Fall 2017 Lid van USF Tampa, Team S1-G1, Leahy Fall 2017
USFT-LEAHY-F17S1G1
4 Leden
5 handleidingen geschreven
Één opmerking
Is there a Nikon repair forum that might provide more detailed information?
this is the clearest instructions so far but I’m sure there are diagnostic codes for more precise troubleshooting
Mermaid - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 21
Altijd: 1,807
