Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
In the event that the bottom cover is damaged or specific wires require access, the bottom cover needs to be removed or replaced. For safety purposes, please remove the battery before working with any electronic components.
Wat je nodig hebt
Use the #00 Phillips-head screwdriver to remove the three 8.44 mm screws.
Use the #00 Phillips-head screwdriver to remove the four 6.3 mm screws.
Use the #00 Phillips-head screwdriver to remove the 2.9 mm screw.
5 andere personen hebben deze handleiding voltooid.
