Inleiding
If you get some CHA - errors on your Camera, it is likely time to replace the CF slot. The part number of the Nikon D70 CF slot is 1F998-181.
Wat je nodig hebt
Remove the two 4.8 mm Phillips screws securing the battery side of the rear cover to the D70.
Remove the two Phillips screws securing the holder of the CF Card Slot.
24 andere personen hebben deze handleiding voltooid.
6 opmerkingen
How do i change out the board with the pins…… second hand cam someone bent alot of pins
I can order board or can i order the whole cf ?
You can find them on ebay real easy. both full assemblies and just the board with the pins
Very nice photos and instructions definitely I will attempt after getting the replacement part.
