Ga door naar hoofdinhoud
Nikon D610 Battery Replacement
Wat je nodig hebt
  1. Nikon D610 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • First, power off the device.
  2. Nikon D610 Battery Replacement: stap 2, afbeelding 1 van 3 Nikon D610 Battery Replacement: stap 2, afbeelding 2 van 3 Nikon D610 Battery Replacement: stap 2, afbeelding 3 van 3
    • Set the camera so that it is sitting on its side.
    • Open the battery compartment door by sliding the release button towards the lens.
    • This will cause the door to "pop" open slightly
  3. Nikon D610 Battery Replacement: stap 3, afbeelding 1 van 2 Nikon D610 Battery Replacement: stap 3, afbeelding 2 van 2
    • Now lift open the battery compartment door.
    • Push the yellow tab lock towards the center to release the battery.
    • This will cause the battery to jump up as there is a spring at the bottom.
    • Pull straight out, slowly on the battery.
    • Make sure you pay attention to which way the battery goes .
Conclusie
Daniel Eagan
606 Reputatie
5 handleidingen geschreven
USF Tampa, Team 4-4, Lacy Spring 2016 Lid van USF Tampa, Team 4-4, Lacy Spring 2016
USFT-LACY-S16S4G4
3 Leden
6 handleidingen geschreven
Één opmerking
This is my kind of fixing )
Loic - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 1,424
