Ga door naar hoofdinhoud
Nikon D5000 Viewfinder Replacement
Wat je nodig hebt
  1. Nikon D5000 Viewfinder Replacement, Back Panel: stap 1, afbeelding 1 van 3 Nikon D5000 Viewfinder Replacement, Back Panel: stap 1, afbeelding 2 van 3 Nikon D5000 Viewfinder Replacement, Back Panel: stap 1, afbeelding 3 van 3
    • The battery door has been removed for clarity, but is not necessary. See this guide for how to remove it.
    • Unscrew the eight Phillips #00 screws on the back panel:
    • Two 2.5x6mm screws above the screen.
    • One 3x6mm screw on the upper part of each side (two total; right side shown).
    • One 3x7.5mm screw on the lower part of each side (two total).
    • Two 3x4.5mm screws on the bottom.
  2. Nikon D5000 Viewfinder Replacement: stap 2, afbeelding 1 van 3 Nikon D5000 Viewfinder Replacement: stap 2, afbeelding 2 van 3 Nikon D5000 Viewfinder Replacement: stap 2, afbeelding 3 van 3
    • Pull the back panel up, then tilt it back. There will be two cables still holding it on.
    • Doing this will also release the connector cover on the left side. Set it aside for now, but remember to reinstall it later.
    • Disconnect the ribbon cable by flipping the black tab up, then pulling the cable out.
    • This procedure also applies to all of the other ribbon cables in the D5000.
    • Pull out the other connector by lifting it up with tweezers, or by prying it out. Fingernails also work well.
  3. Nikon D5000 Viewfinder Replacement, Viewfinder: stap 3, afbeelding 1 van 3 Nikon D5000 Viewfinder Replacement, Viewfinder: stap 3, afbeelding 2 van 3 Nikon D5000 Viewfinder Replacement, Viewfinder: stap 3, afbeelding 3 van 3
    • The viewfinder is held on by the top body piece. To access it, the entire plastic body must be removed. Each piece (back, bottom, front, top) helps secure the next piece.
    • Remove the bottom panel's nine Phillips #00 screws:
    • Four 3x3mm black screws.
    • Five 3x6mm black screws.
    • This 3x6mm screw is hidden under the wall adapter cover.
    • Pull the bottom cover off.
  4. Nikon D5000 Viewfinder Replacement: stap 4, afbeelding 1 van 2 Nikon D5000 Viewfinder Replacement: stap 4, afbeelding 2 van 2
    • The front panel is next. Six screws hold it on.
    • Start by removing four Phillips #00 screws in the top part of the panel:
    • Two black 2.5x4.5mm screws above the lens mount.
    • Two black 2.5x4.5mm screws under the flash (they are the same type of screw as in the above step).
  5. Nikon D5000 Viewfinder Replacement: stap 5, afbeelding 1 van 3 Nikon D5000 Viewfinder Replacement: stap 5, afbeelding 2 van 3 Nikon D5000 Viewfinder Replacement: stap 5, afbeelding 3 van 3
    • Remove two more Phillips #00 screws from the bottom of the camera:
    • One silver 3x4.5mm silver screw, by the right edge.
    • One silver 3x4.5mm screw in the battery compartment.
    • Pull the front panel up and off.
  6. Nikon D5000 Viewfinder Replacement: stap 6, afbeelding 1 van 3 Nikon D5000 Viewfinder Replacement: stap 6, afbeelding 2 van 3 Nikon D5000 Viewfinder Replacement: stap 6, afbeelding 3 van 3
    • Next is the top panel. It is held on by four Phillips #00 screws:
    • Two 3x3.5mm black screws, one by each of the strap mounts.
    • One silver 3x5mm screw on the underside of the panel, about where the "Info" button is. It is the lower of the two in this area, and farther back in the camera.
    • One 3x3mm black screw in the side, under the plus/minus button.
  7. Nikon D5000 Viewfinder Replacement: stap 7, afbeelding 1 van 3 Nikon D5000 Viewfinder Replacement: stap 7, afbeelding 2 van 3 Nikon D5000 Viewfinder Replacement: stap 7, afbeelding 3 van 3
    • Disconnect the third ribbon cable from the right at the top of the back logic board.
    • Lift the top panel up.
    • There are still a number of cables connected to this panel. It cannot be removed completely at this point.
    • Remove the viewfinder hood by pulling outward.
  8. Nikon D5000 Viewfinder Replacement: stap 8, afbeelding 1 van 3 Nikon D5000 Viewfinder Replacement: stap 8, afbeelding 2 van 3 Nikon D5000 Viewfinder Replacement: stap 8, afbeelding 3 van 3
    • Remove the two Phillips #00 3x5.5mm silver screws securing the viewfinder assembly.
    • Remove the three Phillips #00 2.5x3.5mm screws holding the electronics board onto the viewfinder assembly.
    • These are the lower screws in the metal plate, not the upper ones with the springs on them.
  9. Nikon D5000 Viewfinder Replacement: stap 9, afbeelding 1 van 3 Nikon D5000 Viewfinder Replacement: stap 9, afbeelding 2 van 3 Nikon D5000 Viewfinder Replacement: stap 9, afbeelding 3 van 3
    • Remove the viewfinder window.
    • During reinstallation, there is a small tab on the side of the window assembly that needs to be reconnected (window removed for clarity).
    • After reinstalling the window assembly, catch the tab in the metal hook on the viewfinder hood (see third image). Then seat the two plastic pins on the bottom of the hood.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Jacob Rardin
1.390 Reputatie
6 handleidingen geschreven
Cal Poly, Team 13-28, Maness Spring 2014 Lid van Cal Poly, Team 13-28, Maness Spring 2014
CPSU-MANESS-S14S13G28
4 Leden
7 handleidingen geschreven
Één opmerking
So, would it then also be possible to not only clean or replace the viewfinder, but swap out a pentamirror with a pentaprism or upgrade a viewfinder from this?
Shawn Gordon - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 39
Altijd: 9,499
