Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
If your camera stops making noise, or the sound is distorted, you may want to inspect or replace the speaker.
Wat je nodig hebt
Unscrew the eight Phillips #00 screws on the back panel:
Two 2.5x6mm screws above the screen.
One 3x6mm screw on the upper part of each side (two total; right side shown).
One 3x7.5mm screw on the lower part of each side (two total).
Two 3x4.5mm screws on the bottom.
Remove the four Phillips #00 screws securing the shield:
Three silver 3x4mm screws.
One black 3x3mm screw.
Remove the shield.
