Inleiding
If your camera stops making noise, or the sound is distorted, you may want to inspect or replace the speaker.
Wat je nodig hebt
Unscrew the eight Phillips #00 screws on the back panel:
Two 2.5x6mm screws above the screen.
One 3x6mm screw on the upper part of each side (two total; right side shown).
One 3x7.5mm screw on the lower part of each side (two total).
Two 3x4.5mm screws on the bottom.
Remove the four Phillips #00 screws securing the shield:
Three silver 3x4mm screws.
One black 3x3mm screw.
Remove the shield.
