Ga door naar hoofdinhoud
Nikon D5000 Sensor Filter Replacement
Wat je nodig hebt
  1. Nikon D5000 Sensor Filter Replacement, Back Panel: stap 1, afbeelding 1 van 3 Nikon D5000 Sensor Filter Replacement, Back Panel: stap 1, afbeelding 2 van 3 Nikon D5000 Sensor Filter Replacement, Back Panel: stap 1, afbeelding 3 van 3
    • The battery door has been removed for clarity, but is not necessary. See this guide for how to remove it.
    • Unscrew the eight Phillips #00 screws on the back panel:
    • Two 2.5x6mm screws above the screen.
    • One 3x6mm screw on the upper part of each side (two total; right side shown).
    • One 3x7.5mm screw on the lower part of each side (two total).
    • Two 3x4.5mm screws on the bottom.
    Vraag FixBot
  2. Nikon D5000 Sensor Filter Replacement: stap 2, afbeelding 1 van 3 Nikon D5000 Sensor Filter Replacement: stap 2, afbeelding 2 van 3 Nikon D5000 Sensor Filter Replacement: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Pull the back panel up, then tilt it back. There will be two cables still holding it on.
    • Doing this will also release the connector cover on the left side. Set it aside for now, but remember to reinstall it later.
    • Disconnect the ribbon cable by flipping the black tab up, then pulling the cable out.
    • This procedure also applies to all of the other ribbon cables in the D5000.
    • Pull out the other connector by lifting it up with tweezers, or by prying it out. Fingernails also work well.
    Vraag FixBot
  3. Nikon D5000 Sensor Filter Replacement, Sensor Filter: stap 3, afbeelding 1 van 3 Nikon D5000 Sensor Filter Replacement, Sensor Filter: stap 3, afbeelding 2 van 3 Nikon D5000 Sensor Filter Replacement, Sensor Filter: stap 3, afbeelding 3 van 3
    • Disconnect the six ribbon cables by releasing the clips and pulling the cables out.
    • Pry off the gold-plated connector with an opening tool, spudger, tweezers, or a fingernail.
    • Disconnect a seventh ribbon cable in the lower-right corner.
    Vraag FixBot
  4. Nikon D5000 Sensor Filter Replacement: stap 4, afbeelding 1 van 1
    • Desolder the five wires attached to the back of the board.
    Vraag FixBot
  5. Nikon D5000 Sensor Filter Replacement: stap 5, afbeelding 1 van 2 Nikon D5000 Sensor Filter Replacement: stap 5, afbeelding 2 van 2
    • Remove the five silver Phillips #00 4x4mm screws.
    • One is hiding under the wide ribbon cable in the lower-right corner.
    Vraag FixBot
  6. Nikon D5000 Sensor Filter Replacement: stap 6, afbeelding 1 van 2 Nikon D5000 Sensor Filter Replacement: stap 6, afbeelding 2 van 2
    • Flip up the motherboard.
    • Remove the white cable connector by pulling it out of its socket with a spudger or fingernails.
    Vraag FixBot
  7. Nikon D5000 Sensor Filter Replacement: stap 7, afbeelding 1 van 2 Nikon D5000 Sensor Filter Replacement: stap 7, afbeelding 2 van 2
    • Remove the L-shaped ribbon cable from both of its connectors.
    Vraag FixBot
  8. Nikon D5000 Sensor Filter Replacement: stap 8, afbeelding 1 van 2 Nikon D5000 Sensor Filter Replacement: stap 8, afbeelding 2 van 2
    • Remove the three silver 5x5mm screws.
    • Between the metal backing plate and the standoffs for each screw is a copper washer. Don't lose them!
    • Flip the sensor board out.
    • Be extremely careful from this point on. Dust or scratches on any part of the sensor or its filters can affect picture quality.
    Vraag FixBot
  9. Nikon D5000 Sensor Filter Replacement: stap 9, afbeelding 1 van 2 Nikon D5000 Sensor Filter Replacement: stap 9, afbeelding 2 van 2
    • Remove the four silver 3.5x3.5mm screws securing the dust cover.
    • Pull the cover straight up to remove it.
    Vraag FixBot
  10. Nikon D5000 Sensor Filter Replacement: stap 10, afbeelding 1 van 2 Nikon D5000 Sensor Filter Replacement: stap 10, afbeelding 2 van 2
    • To remove the sensor filter, pull back the rubber gasket to expose the edge. Use a spudger or opening tool to carefully pry out the filter.
    Vraag FixBot
Conclusie
3 andere personen hebben deze handleiding voltooid.
Jacob Rardin
1.472 Reputatie
6 handleidingen geschreven
Cal Poly, Team 13-28, Maness Spring 2014 Lid van Cal Poly, Team 13-28, Maness Spring 2014
CPSU-MANESS-S14S13G28
4 Leden
7 handleidingen geschreven
2Gids Commentaar
Excelente guía, solo que debo cambiar las cortinillas y creo que es por el frente de la cámara
alcova35 - Antwoord Deel
Is the dust cover in step 9 just a clear glass or is it also a filter? In the picture, it has a pink tint.
pol techa - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 76
Altijd: 6,069
