Ga door naar hoofdinhoud
Nikon D5000 LCD Screen Replacement
Wat je nodig hebt
  1. Nikon D5000 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 1 van 3 Nikon D5000 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 2 van 3 Nikon D5000 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 3 van 3
    • The battery door has been removed in these photos, but this step is not necessary.
    • Flip out the screen. There are four Philips #00 screws securing the black plastic case.
    • The screws are located symmetrically: one on the left side, one on the right side, and two on the bottom (on either side of the hinge).
    • Detail of a 2x2.5mm side screw.
    • Detail of the two 3x4mm bottom screws.
  2. Nikon D5000 LCD Screen Replacement: stap 2, afbeelding 1 van 3 Nikon D5000 LCD Screen Replacement: stap 2, afbeelding 2 van 3 Nikon D5000 LCD Screen Replacement: stap 2, afbeelding 3 van 3
    • The back of the case is held on by four snaps.
    • Using plastic opening tools, pop the back cover off. Start from the bottom of the case, by the hinge.
    • The locking tab and its spring (at the top of the screen; marked in red) are loose and may fall out. Keep the screen horizontal when removing the cover.
    • Replace the tab and spring during reassembly, if removed.
  3. Nikon D5000 LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Pull straight up to remove the front panel.
    • This gives access to both the screen and the underside of the screen protector, allowing either or both to be cleaned.
  4. Nikon D5000 LCD Screen Replacement: stap 4, afbeelding 1 van 3 Nikon D5000 LCD Screen Replacement: stap 4, afbeelding 2 van 3 Nikon D5000 LCD Screen Replacement: stap 4, afbeelding 3 van 3
    • Slide the screen assembly forward and off of the hinge mount.
    • With a spudger, opening tool, or fingernail, pop up the clip on the wide ribbon cable.
    • Using tweezers, slide the dark brown portion of the connector down. This will release the lower ribbon cable.
    • Slide both cables out of their connectors.
  5. Nikon D5000 LCD Screen Replacement: stap 5, afbeelding 1 van 1
    • Pry the circuit board off of the adhesive on the back of the screen. Use a spudger or opening tool.
    • The metal frame is loose at this point. You may want to flip it up and out of the way for this step.
    • The circuit board is flexible, but be careful not to permanently bend or break it!
  6. Nikon D5000 LCD Screen Replacement: stap 6, afbeelding 1 van 1
    • Remove the LCD screen.
    • If the adhesive makes it too difficult to remove the circuit board, try heating the screen slightly. Be careful not to let the circuit board or screen overheat.
    where i can buy lcd it self. paste link if can. tqsm.
    Md Zawawi DIY - Antwoord
Conclusie
11 andere personen hebben deze handleiding voltooid.
Jacob Rardin
1.390 Reputatie
6 handleidingen geschreven
Cal Poly, Team 13-28, Maness Spring 2014 Lid van Cal Poly, Team 13-28, Maness Spring 2014
CPSU-MANESS-S14S13G28
4 Leden
7 handleidingen geschreven
5 opmerkingen
Great guide. Very thorough and the images were most helpful. Worked for me! THANKS.
Ronald Schnaar - Antwoord
When I open my D5000 i found out that the Blue and Orange wire on the board was disconnected and had no Idea where it goes (until i saw in the picture then I figured it out). But Overall I managed to assesmble the LCD and was feeling great. Although everytime I change the LCD view upsidedown, it doesnt respond to it unlike putting the view left or right (that works..i wonder why?). Thanks for the guide
http://i.imgur.com/eohsKCp.jpg
http://i.imgur.com/EiC5UI7.jpg
luqmanhakim62 - Antwoord
Hi, I also have the blue wire disconnected. Despite this, my screen appears fully functional. Anyone knows what this wire is supposed to do..?
Thanks, the guide is perfect!
Daniele Trimarchi -
Menu buttons are not working or all buttons. I can take pictures,LV button is not working. How can I repair? Thank you very much!!!
Duang Bouphasavanh - Antwoord
the pin lock to the wide ribbon cable is brittle already, is there another way to reattach the cable?
Fer Basbas - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 15
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 96
Altijd: 17,408
