Ga door naar hoofdinhoud
Nikon D5000 Battery Door Replacement
  1. Nikon D5000 Battery Door Replacement, Battery Door: stap 1, afbeelding 1 van 2 Nikon D5000 Battery Door Replacement, Battery Door: stap 1, afbeelding 2 van 2
    • On the bottom of the camera, pull the release tab towards the center of the camera, then pull up.
  2. Nikon D5000 Battery Door Replacement: stap 2, afbeelding 1 van 2 Nikon D5000 Battery Door Replacement: stap 2, afbeelding 2 van 2
    • Grip and hold the front end of the battery door at a 45-degree angle from the case.
    • Pop the battery door out by pulling the front tab up.
    • When reassembling, seat the rear tab in its slot before pushing the front tab back in.
Conclusie
Jacob Rardin
1.390 Reputatie
6 handleidingen geschreven
Cal Poly, Team 13-28, Maness Spring 2014 Lid van Cal Poly, Team 13-28, Maness Spring 2014
CPSU-MANESS-S14S13G28
4 Leden
7 handleidingen geschreven
Één opmerking
My problem is the door on my Nikon D850 broke, leaving the small part with the two prongs in place, and I don’t know how to get them out to install a replacement door. Would appreciate suggestions tootswaller22@gmail.com
Harry Langdon - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 81
Altijd: 4,915
