Ga door naar hoofdinhoud
Nikon D3000 Motherboard Replacement
Wat je nodig hebt
  1. Nikon D3000 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 2 Nikon D3000 Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • Remove six 3 mm x 2.5 mm Phillips head screws from the bottom right of the camera bottom.
    • Remove three 3 mm x 5.5 mm Phillips head screws from the bottom left of the camera bottom
    • Lift the battery cover and remove two 3 mm x 5 mm Phillips head screws.
  2. Nikon D3000 Motherboard Replacement: stap 2, afbeelding 1 van 3 Nikon D3000 Motherboard Replacement: stap 2, afbeelding 2 van 3 Nikon D3000 Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Remove the two 3 mm x 5.5 mm Phillips head screws from the either side of the viewfinder.
    • Remove four 3 mm x 5.5 mm Phillips head screws from the sides of the camera.
    • Remove two 3 mm x 4 mm Phillips head screws from under the SD card door.
  3. Nikon D3000 Motherboard Replacement: stap 3, afbeelding 1 van 2 Nikon D3000 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Use the following process for removing all ribbon connectors.
    • Lift the back of the camera and, using the blue prying tool, lift the tab from the LCD ribbon connector.
    • Slide the ribbon connector away from the bottom of the camera and remove the back cover containing the LCD to expose the motherboard.
  4. Nikon D3000 Motherboard Replacement: stap 4, afbeelding 1 van 2 Nikon D3000 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Soldering irons are hot; take all necessary precautions to not burn yourself or equipment.
    • Be sure to label each gray wire to be removed from the motherboard as they are the same color and can be mixed up during reassembly.
    • Lift the tab on the ribbon connector and pull away the ribbon to expose a 4 mm x 4 mm Phillips head screw.
    • De-solder the red (upper), two grey (lower), red (lower), and blue (lower) wires from the motherboard.
    • Remove five 4 mm x 4 mm Phillips head screws holding the motherboard to the camera frame.
  5. Nikon D3000 Motherboard Replacement: stap 5, afbeelding 1 van 2 Nikon D3000 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Lift the tabs and pull away the ribbon connectors shown .
    • Lift the motherboard and disconnect the grey connector from the bottom.
    • Disconnect and remove the motherboard.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Randall Heath
824 Reputatie
3 handleidingen geschreven
USF Tampa, Team 14-7, Meier Fall 2015 Lid van USF Tampa, Team 14-7, Meier Fall 2015
USFT-MEIER-F15S14G7
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 47
Altijd: 3,673
